L555 Deluxe
plumalan
I recently had a solenoid replaced that fed juice to the glow plugs. It starts cold now but the bucket will not flip up or down. Time I started it after the solenoid replacement, the bucket would not tilt. The boom rises with no problem. Bucket will not tilt more than an inch up or down. With pedal depressed the engine seems to pull down slightly. Help I have no experience with hydraulics or electrical. I am located in Hillsborough county in Florida
The only thing i can think of is to check around where they were working, see if something have been bumped to dislodge a connector?
Looking at schematic the glow plugs have a relay listed as item 14. Next to it is a curl solenoid item 24. Check if the curl #24 is plugged in. Just guessing that curl means bucket operation. Wires may have been disturbed.Make sure the seat belt is plugged in bucket won't curl if it is not. Check that the tree lights are all out. Just a thought and good luck.
