L455 Flex Plate
DonD
The internal splines on my L455 flex-plate (699154) to pump are stripped. I tried to find a replacement but salvage companies and parts sellers I have contacted were out of stock and could not give a lead time for availability. My local machine shops I contacted said they could not do anything with internal splines. Does anyone know where I can find a replacement flex plate or knows of a shop that could repair/replace the female splines? Is there another repair approach I should consider? Any advice would be appreciated.
You may be able to get a 13T x 16/32 (7/8") coupling, and remove/ replace (weld) the damaged spline sleeve in the center of the flex plate. -stef
Call All All States AG Part 1-877-530-4430 there are two diffrent ones used depending on serial number of loader Part # 699154 befoe S/N 717400 Part # 9609348 after S/N 717700 they are avaiable through New holland parts yet but very spendy also shaft Part number 274905 is avaialbe at Messisks Elizbethtown PA 1-877-260-3528 $210.00 plus shipping Messicks has the flex plate also
