Other Brand Skidsteer Forums
New Holland Skidsteer Forum
L35 Starter solenoid and wiring help request.
Reply to thread
Message
<blockquote data-quote="Mike10" data-source="post: 47160" data-attributes="member: 5461"><p>The terminal with the battery cable should also have two other wires on it. One goes to the ignition switch and the other to the alternator. The other small wire that attaches to the "S" terminal recieves power when the key is turned to start or if you have a push buttom it comes from that switcch.</p></blockquote><p></p>
[QUOTE="Mike10, post: 47160, member: 5461"] The terminal with the battery cable should also have two other wires on it. One goes to the ignition switch and the other to the alternator. The other small wire that attaches to the “S” terminal recieves power when the key is turned to start or if you have a push buttom it comes from that switcch. [/QUOTE]
Verification
Post reply
