Howdy, I have a L230 that every once in a while it throws 3141 code, keeps running fine, just beeps. If I turn it off and restart, it’s gone. Next day EST shows the code inactive. I have checked and cleaned the rail pressure sensor and engine connectors with no luck, with a meter hooked up and each end and moving wires I don’t get a fault. Looking at the service manual the next step would be maybe replace the rail pressure sensor or the bypass valve on the rail. These parts are expensive and would like some advice before throwing parts at it. Thanks in advance.
Code 3141 is fuel pressure out of range.
