Its leaking diesel from the pump on the engine block sideWhat menas back side.... between the engine housing and the pump, the accelerator lever side, the high pressure pipes side or the opposite side of the accelerator lever? What is leaking..oil or fuel? It is a Bosh VE pump.It may be an easy repair if you told me corect information.
All pipes are there.Clean conectors carefully and try to see which is leaking . It is easier to see with a mirror and a flashlight.Its leaking diesel from the pump on the engine block side
Not leaking where it mounts to the blockAll pipes are there.Clean conectors carefully and try to see which is leaking . It is easier to see with a mirror and a flashlight.
Yes i know. On this side /between pump and enjine has all diesel connectors - low pressure,high pressure and return line/. Some of these are leaking. Vipe them and look wich is leaking..Not leaking where it mounts to the block
Will I need to pull the pump off to do that, and what do I need to know to do that (tricks)Yes i know. On this side /between pump and enjine has all diesel connectors - low pressure,high pressure and return line/. Some of these are leaking. Vipe them and look wich is leaking..
Nono.no.You dont nedd to pul a pumpmp. Just use a stick or screwdriver, put a little rag on it and try to dash. Look with a mirror and torch from which tube drips to correct it you do not need to remove the pump.Will I need to pull the pump off to do that, and what do I need to know to do that (tricks)
Ok I will try, please stay tunedNono.no.You dont nedd to pul a pumpmp. Just use a stick or screwdriver, put a little rag on it and try to dash. Look with a mirror and torch from which tube drips to correct it you do not need to remove the pump.
