Other Brand Skidsteer Forums
New Holland Skidsteer Forum
L185 Fuel Issues
Reply to thread
Message
<blockquote data-quote="Reelhooker1414" data-source="post: 61986" data-attributes="member: 8453"><p>Should I see fuel coming into return line as I manually pump? Do I crack the lines at the injection pump or the injectors? I have a vacuum pump, any harm in suction on the lines, like the return line? Should I see fuel at the line at the top of the injection pump like it says in the book? I did try turning it over by hand without any difference in the feel of the handle. Is there any way I bound the injection pump with air when I pumped without the bolt cracked open? Any way to fully drain the injection pump?</p></blockquote><p></p>
[QUOTE="Reelhooker1414, post: 61986, member: 8453"] Should I see fuel coming into return line as I manually pump? Do I crack the lines at the injection pump or the injectors? I have a vacuum pump, any harm in suction on the lines, like the return line? Should I see fuel at the line at the top of the injection pump like it says in the book? I did try turning it over by hand without any difference in the feel of the handle. Is there any way I bound the injection pump with air when I pumped without the bolt cracked open? Any way to fully drain the injection pump? [/QUOTE]
Verification
Post reply
L185 Fuel Issues
