Kubota engine mount
junkbud
we need to replace a V2203 with a V1902 Kubota engine. the bolt pattern is completely different on the smaller engine. bobcat has a sideways mount for engine & pump, we need that mount for the V1902, any ideas??
I have the swap mounts. $300 plus shipping or $300 free shipping with your V1903 mount trade. Water jet cut. 62-327-3490
Hey man,
It looks like the guy above might have the easiest solution for you if you want a bolt-on part.
If not, another way to go is to make a simple adapter plate. I've seen a lot of guys do this. You just get a thick piece of steel, drill holes to match your new V1902 engine, and then drill another set of holes that line up with your machine's original mounts. A local welding or machine shop could probably make one for you pretty cheap if you don't have the tools.
Good luck with the project, hope you get it sorted out!
