I just bought this machine about 4 days ago. While testing it out, I noticed it was moving all on its own. After lifting the cab, I found the left side steer control was horribly loose. I took my self down to the STEALERSHIP to get two new levers that attach to the steering pumps. I also replaced the small rubber bushings in those arms, along with the other rubber bushings in the forward control lever linkages. When I was all done, I used the technique I found on this forum to properly set up the swash plate adjustment to keep the machine from creeping when turned on. I wanted to post this as a "THANK-YOU" for all of the technical expertise I've found here. Without you guys on here, I would never have gotten this machine right. For the record, this is the second machine that I've repaired in this manner. The first one is what prompted me to buy this one with complete confidence in what repair it would need. So, without taking up much more of your time, THANK YOU ALL WHO'VE CONTRIBUTED TO THIS FORUM TO MAKE IT ALL THAT IT HAS BECOME FOR ITS MEMBERS!!
