Bobcat Skidsteer Forums
Just bought a 371
Reply to thread
Message
<blockquote data-quote="SkidRoe" data-source="post: 89013" data-attributes="member: 3290"><p>Weak spark is better than no spark. </p><p>I think the next thing I would do before spending a lot of time and money on this engine is a compression test. Squirt a bit of oil in the cylinder, install the compression tester, and hold the carb wide open while you are spinning the engine with the starter. </p><p>You should be looking for a compression pressure of greater than 90 psi.</p><p>HTH - SR</p></blockquote><p></p>
[QUOTE="SkidRoe, post: 89013, member: 3290"] Weak spark is better than no spark. I think the next thing I would do before spending a lot of time and money on this engine is a compression test. Squirt a bit of oil in the cylinder, install the compression tester, and hold the carb wide open while you are spinning the engine with the starter. You should be looking for a compression pressure of greater than 90 psi. HTH - SR [/QUOTE]
Verification
Post reply
Just bought a 371
