Bobcat Skidsteer Forums
John Deere 323D not quite right?
Reply to thread
Message
<blockquote data-quote="split" data-source="post: 140111" data-attributes="member: 9607"><p>I just performed the test. 2800RPMs will full forward on both drive sticks in park. Pressure went to 19 PSI. That says the turbo is fine.</p><p>There is something very wrong with the machine, it can't even move itself forward at idle. It makes such a horrible laboring sound if you try. I spoke with another 323D owner and he said his could move without issue at idle, although very slowly. If the engine is fine, then it must be hydraulics, I would guess.</p><p>I need to measure the hydraulic pressure next.</p><p>I noticed that I originally posted this on the Bobcat forum rather than the Deere forum...Not sure why, but I suspect its because there is little posting going on on the deere skidsteer forum</p><p></p><p>I have created a new post there: <a href="https://www.skidsteerforum.com/threads/2011-323d-sick.121831/" target="_blank">https://www.skidsteerforum.com/threads/2011-323d-sick.121831/</a></p></blockquote><p></p>
[QUOTE="split, post: 140111, member: 9607"] I just performed the test. 2800RPMs will full forward on both drive sticks in park. Pressure went to 19 PSI. That says the turbo is fine. There is something very wrong with the machine, it can't even move itself forward at idle. It makes such a horrible laboring sound if you try. I spoke with another 323D owner and he said his could move without issue at idle, although very slowly. If the engine is fine, then it must be hydraulics, I would guess. I need to measure the hydraulic pressure next. I noticed that I originally posted this on the Bobcat forum rather than the Deere forum...Not sure why, but I suspect its because there is little posting going on on the deere skidsteer forum I have created a new post there: [URL]https://www.skidsteerforum.com/threads/2011-323d-sick.121831/[/URL] [/QUOTE]
Verification
Post reply
