John Deere 320D problem
alaska1
I have a 2010 JD 320D skid steer and it is setting the park brake off and on while operating. It does this right after beeping and showing " check service code" when I check codes it has no active but has a JSR stored code and when selected reads.... Right Joystick Y-Axis.... can not see anything consecutive about when this happens. Took it to dealer in Billings. Mt. and spent over $500 and did not fix it. They (think) it may need new joystick or joysticks. They are over $1000. each. The machine only has 600 hrs. Anyone had this issue.... any suggestions............ TIA....... Is it a bad idea to pull joystick, clean and replace........... would that cause it to need re calibrating......... thanks again...
