John Deere 318D Hand and foot valve leaking
CWR
The right hand drive main shaft into the valve housing is leaking. This is directly under the centering MECHANISM. The parts blow up shows two screws that hold the shaft guide/valve body plug in place. After removing the centering MECHANISM and accessing the top of the valve body i have a smooth round pulg/plate? With no bolts for removal of the guide/plug/shaft. Anyone know if this is a cover and if so how to remove it? And if not how do i access the control shaft so i can replace the seals? The round is smooth with no detents to pull/turn etc.
