Other Brand Skidsteer Forums
John Deere Skidsteer Forum
JD ct322 Starts and stalls.
Reply to thread
Message
<blockquote data-quote="geroy69" data-source="post: 86039" data-attributes="member: 12187"><p>Update. Pushing the bypass switch didn't work, so I call the dealer and they send the mechanic, the mechanic came over and power up the fuel solenoid from the battery, so the engine started with no problems and didn't shut down, so he said that solenoid is working fine and thats a DMU computer is sending Auto shut down, so then I told him what I did with the auxiliary handle and he trace that to the switch that sends the signal to DMU that the auxiliary handle is in neutral so we jump the connections on the switch and BINGO, so when I push the lever its trigger the switch in off position and because nobody ever use the auxiliary on this machine the connections got bad inside the switch, the switch is $35. Thank you all for the help.</p></blockquote><p></p>
[QUOTE="geroy69, post: 86039, member: 12187"] Update. Pushing the bypass switch didn't work, so I call the dealer and they send the mechanic, the mechanic came over and power up the fuel solenoid from the battery, so the engine started with no problems and didn't shut down, so he said that solenoid is working fine and thats a DMU computer is sending Auto shut down, so then I told him what I did with the auxiliary handle and he trace that to the switch that sends the signal to DMU that the auxiliary handle is in neutral so we jump the connections on the switch and BINGO, so when I push the lever its trigger the switch in off position and because nobody ever use the auxiliary on this machine the connections got bad inside the switch, the switch is $35. Thank you all for the help. [/QUOTE]
Verification
Post reply
