Other Brand Skidsteer Forums
John Deere Skidsteer Forum
JD 260 Hydraulic Issues
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 26012" data-attributes="member: 82"><p>Air will self belld over time, so you don't need to worry about purging it.</p><p>Pk, the pedals not moving means you do have some sort of safety lockout, i'm just not sure what, deere is new to me, they are all essentially the same in operation though.</p><p>The pickup screen could be anywhere, i know the old bobcats had one hidden in the port block. You could call your dealer and talk to the service dept. see if they can tell you if there is one. When plugged the drive is usually the one to suffer, and not the lift/tilt functions.</p><p>That lifting ability is about rite, stone is rather heavy plus the weight of the bucket.</p><p>Without an attachment on the hydraulics you would need to crack the couplers to see if when its running if its spraying oil out. Its normal to get a small amount of flow at very low pressure but not a spray.</p><p>The relief is on the control block.</p></blockquote><p></p>
[QUOTE="Tazza, post: 26012, member: 82"] Air will self belld over time, so you don't need to worry about purging it. Pk, the pedals not moving means you do have some sort of safety lockout, i'm just not sure what, deere is new to me, they are all essentially the same in operation though. The pickup screen could be anywhere, i know the old bobcats had one hidden in the port block. You could call your dealer and talk to the service dept. see if they can tell you if there is one. When plugged the drive is usually the one to suffer, and not the lift/tilt functions. That lifting ability is about rite, stone is rather heavy plus the weight of the bucket. Without an attachment on the hydraulics you would need to crack the couplers to see if when its running if its spraying oil out. Its normal to get a small amount of flow at very low pressure but not a spray. The relief is on the control block. [/QUOTE]
Verification
Post reply
