Other Brand Skidsteer Forums
John Deere Skidsteer Forum
JD 240 won't maintain rpm / knocks like a jackhammer !
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 26450" data-attributes="member: 82"><p>With a fuel injector, you have high pressure diesel that goes to it, the nozzle lifts up and squirts the fuel out. If its dirty or has something stuck in the seat it will not spray correctly or not close. Fuel can then form droplets and drop fuel out and not spray it in a mist for ignition. This fuel can burn holes in the pistons. But it usually does cause power loss and shaking of the engine due to that cylinder not firing correctly and black smoke.</p></blockquote><p></p>
[QUOTE="Tazza, post: 26450, member: 82"] With a fuel injector, you have high pressure diesel that goes to it, the nozzle lifts up and squirts the fuel out. If its dirty or has something stuck in the seat it will not spray correctly or not close. Fuel can then form droplets and drop fuel out and not spray it in a mist for ignition. This fuel can burn holes in the pistons. But it usually does cause power loss and shaking of the engine due to that cylinder not firing correctly and black smoke. [/QUOTE]
Verification
Post reply
