JCB 1CXT is backhoe
lattoniere
The JCB 1CXT is a unique, compact tracked backhoe loader (approx. 9,572 lb) that combines skid steer maneuverability with backhoe digging power. It features a 49 hp engine requiring no DEF/DPF, a max dig depth over 10 ft, and a universal quick hitch for attachments. Its tracked design offers superior stability, low ground pressure, and effortless towing without a CDL
  • Engine: 49 hp (36.3 kW) diesel engine.
  • Performance: Max dig depth of 10 ft 1 in (3.08 m) with an extending dipper.
  • Tracks: 320 mm (12.8 in) rubber tracks for low ground pressure.
  • Dimensions: Under 6 ft wide and 7 ft 10 in tall, ideal for tight access.
  • Operating Weight: 9,396 lb - 9,572 lb.
  • Hydraulics: Standard flow at 10 GPM, with high-flow options available.
    JCB Home +4
Key Advantages
  • Versatility: The universal quick hitch makes it compatible with most skid-steer attachments.
  • Ease of Use: Features a swiveling seat to move between loader and excavator controls, with an optional hand-held tool auxiliary circuit.
Work Capabilities
  • Loader: Parallel lift as standard.
  • Excavator: 90-degree excavation, with stabilizers that only need to be deployed for heavy-duty digging.
  • Transport: Easy to tow on a trailer due to its low weight
JCB, Backhoe Loader, Model 1CXT
What do you think of this backhoe? Is it better to have a tracked or wheeled version for the countryside? What's the difference in cost between the two versions? I see it as a very versatile utility vehicle. Thanks. Is a backhoe better, or are both excavators and a mechanical shovel better? I'll make the observation. The excavator is more stable, balanced, and versatile. It rotates 360 degrees, loads vehicles better, and has a dozer blade for laying paths and leveling. The backhoe does many versatile jobs, but it's limited compared to the excavator. What do you think? Thanks.
    950 bytes
