Bobcat Skidsteer Forums
Is this a good price ??
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 16650" data-attributes="member: 82"><p>True, just remember the larger the machine the tight spaces you just can't get into as well. It will also use more fuel. I'm really not sure how popular this size machine is over here as 90% of them are the "7" series size, weighing about 2 tonne and rated to lift about 700kg, but they can lift more. Just keep these points in mind when you decide.</p><p>I'm not sure what engines these run, but i'm assuming a detuz oil cooled, if you go the for higer hour one, you really should get the timing belt changed as soon as you get it, if it fails you will bend all your push rods and may cause valve and piston damage too. I can't remember how many hours before it needs to be changed but other members in here have been caught before!</p><p>Good</p></blockquote><p></p>
[QUOTE="Tazza, post: 16650, member: 82"] True, just remember the larger the machine the tight spaces you just can't get into as well. It will also use more fuel. I'm really not sure how popular this size machine is over here as 90% of them are the “7” series size, weighing about 2 tonne and rated to lift about 700kg, but they can lift more. Just keep these points in mind when you decide. I'm not sure what engines these run, but i'm assuming a detuz oil cooled, if you go the for higer hour one, you really should get the timing belt changed as soon as you get it, if it fails you will bend all your push rods and may cause valve and piston damage too. I can't remember how many hours before it needs to be changed but other members in here have been caught before! Good [/QUOTE]
Verification
Post reply
