Bobcat Skidsteer Forums
instalation of park brake 763
Reply to thread
Message
<blockquote data-quote="OldMachinist" data-source="post: 52187" data-attributes="member: 437"><p>The wire colors to the solenoid would have been white, black and red. On some some machines the red wire is pink/red and those machines instead of a white that wire is red. The red wire(red/pink) goes to the BICS box and the other two connect to the engine wiring harness with some 2 other wires(pink/white and orange).</p><p>The reason you just can't hook it up to 12 volts is that it has 2 coils. A pull coil and a hold coil. If you apply 12v constant to the pull coil it will burn out.</p></blockquote><p></p>
[QUOTE="OldMachinist, post: 52187, member: 437"] The wire colors to the solenoid would have been white, black and red. On some some machines the red wire is pink/red and those machines instead of a white that wire is red. The red wire(red/pink) goes to the BICS box and the other two connect to the engine wiring harness with some 2 other wires(pink/white and orange). The reason you just can't hook it up to 12 volts is that it has 2 coils. A pull coil and a hold coil. If you apply 12v constant to the pull coil it will burn out. [/QUOTE]
Verification
Post reply
