I have a persistent leak in the return hydraulic hose on the right side boom hydraulic cylinder. The hose drops into the frame on that right side and is strategically situated just blow the frame connecting to a solid pipe feeding from the pump. I was able to remove several items to access the hydraulic tube support bracket and loosen that bolt allowing me to pull the hose down and back for inspection. The delima is that one can not get a tool in that area to disconnect the hose from the tubing. My next move is to open the cab and try to remove the tube from its junction with the pump. Do any other members have experience replacing the right side hoses on a 751 skid steer?
