michaeljhetzel
- Joined
- Mar 9, 2025
- Messages
- 10
First, Id like to thank the response’s that I received for the 742 Ford gas motor and install an igniter and do away with the points. Thanks for the resistor information, and now everything seems good. The machine runs great!
Now, I inherited this machine from my father and I use it in far northern Wisconsin. Pretty much just to clear snow and very occasionally in the summer. Lucky if I put on 8-10 hours a year. Two years ago I changed the hydraulic fluid, filter and cleaned a (I think it’s called a port block filter??) it was like a stone type filter that was quite dirty. After all the fluid drained I was told to put in AW46 hydraulic fluid. Now I read that it says to replace it with 10W-30 or 10W40 class SE motor oil?? What should I use? Is the hydraulic fluid in there now okay? Also, any other filters that I should know about.
