I need a control valve....
If you have the bobcat part number, I have a couple contacts for you to try. Send me a message if so.
I have a 643 I am parting out I think this is the same control valve. What's wrong with yours?
Not real sure, I put new seals in and new detent balls... after that worked ok for a while then the lift spool started "hanging" to the point I had to stomp the pedal to get into float mode, now ok occasionally.
I would try it for a while, could be a little foreign material got in the valve body when you were working on it. Easy to do. Spools have 1/2 the thickness of a hair or less clearance. It may work itself out.
I thought so at first also and have run it awhile. The detent started to locke up a couple time and was able to get it free. I think the valve body must have some rusty erosion around the detent lockout.
