hydro rpm
adsmith72
What are the hydros rated for on rpm? I saw a spec in the service manual that said 2600. The motor i bought is set for 3600. Its a v 1305 kubota. Just want to check bfore i get it in there. Thanks Aaron
That is a Kubota diesel? Seems a little high to me. That figure will be it's max speed, you won't need to rev it that high.
It also depends on the gearing to your pump. If it's belt drive it can be lowered, if it's direct you can't. It also depends on the pump for the speed it is meant to operate best at.
