Other Brand Skidsteer Forums
New Holland Skidsteer Forum
hydro charge light
Reply to thread
Message
<blockquote data-quote="irvi00" data-source="post: 37747" data-attributes="member: 3948"><p>You can't hurt these older machines, listening to it will tell you more than the warning lights. If a pump or motor is starving for fluid, you can hear it screaming. Just work the air out it. Check the fluid screen at your right foot, behind the shroud. It's a tube. opened by a half inch drive ratchet. Clean that, then consider changing hydraulic filters.</p></blockquote><p></p>
[QUOTE="irvi00, post: 37747, member: 3948"] You can't hurt these older machines, listening to it will tell you more than the warning lights. If a pump or motor is starving for fluid, you can hear it screaming. Just work the air out it. Check the fluid screen at your right foot, behind the shroud. It's a tube. opened by a half inch drive ratchet. Clean that, then consider changing hydraulic filters. [/QUOTE]
Verification
Post reply
hydro charge light
