Bobcat Skidsteer Forums
Hydraulic problem with arm cylinder on cat excavator
Reply to thread
Message
<blockquote data-quote="scottyk" data-source="post: 16292" data-attributes="member: 1126"><p>Found the problem and machine is operable again. Spool valve for the circuit was a little rusty in the middle area. Put some emery cloth to it and put everything back and it's as good as new. Thanks fishfiles, spool had spring on it as you described and oppositte side cap had to be removed. Mahalo for all your help; saved me time and money.</p></blockquote><p></p>
[QUOTE="scottyk, post: 16292, member: 1126"] Found the problem and machine is operable again. Spool valve for the circuit was a little rusty in the middle area. Put some emery cloth to it and put everything back and it's as good as new. Thanks fishfiles, spool had spring on it as you described and oppositte side cap had to be removed. Mahalo for all your help; saved me time and money. [/QUOTE]
Verification
Post reply
