hydraulic oil
dm4453
What does everyone like to use. I have seen 10/30 or 10/40 motor oil or transdraulic. Draining my system tomorrow to pull the filter in the hydraulic block as I think that is what is causing my forward and back not to work on my early 80s 742 with the ford. Appears I have to tip the cab back to do this. if there are any secrets out ther on this filter let me know and what type and brand hydraulic oil people like
Most use 10-30 or 10-40 I use 15-40 because its cheaper and use just one oil for everything in my 743 but live in Texas........when you pull the filter pull it out with the sleave to keep crud out......and tie the cage back GOOD it can hurt you bad
Thanks. Are you talking about regular car 10/30 motor oil
Are there any other fluid levels to check. Engine oil and the hydraulic resoviour but does that lube the chain drive on the axles or is it all contained in one system. On a side note I did replace the micron filter in the cyclinder blovk and it was dirty. A scerrn door tuen buckle was the perfect fit to screw on and the you could use a pliers and pull straight out. Filling with oil tomorrow so I hope it solves the back and forth not working well
The chain case is seperate the plug is in the front to fill but need to take the top off to pump and clean out good rag out and refill from the top
Sounds like your checking it out while your at it check the u-joints and grease them very important also pick it up and check the wheels for play a inch and a half front to back before the other tire moves and nothing in and out
