Hydraulic light on and my LS 180
Forrest
My LS 180 while running the Hydraulic light comes on and after 3 mins running it shuts down. It will start back up and and dose the same thing. I've owned the skidd steer since new. It has 2000 on it. Any help.
Replace the charge pressure sensor. Lift and latch the seat up. While looking in from the front, the right hydro pump attached to the engine bell housing has a smalll rubber hose attached to a fitting on top. Follow the hose and at the end is the sender. Usually stuffed behind the engine fuse panel.
