Hydraulic issue
tucker816
I have a hydraulic issue with my 2003 Bobcat T190. I was running a bush hog attachment. When I was done bush hogging I noticed my auxiliary would not turn off. My bush hog continued to run. I turned my auxiliary back on and toggled the on/off on the joystick a few times and it stopped. I unhooked my bushhog and shut off the machine. When I started it back up the auxiliary pump was off and my arm and tilt went up but would not come down they just stayed locked. I got a code for hydraulic filter charge not connected. I noticed when I turn the max flow only button on and toggle the right trigger I can use my arms and tilt again.
What Code you got?
All it said was "hydraulic charge filter not connected"
Press the light button on the LH Panel for 3 seconds, while the code is present and write down the xx-xx code. It might scrolls automatically to a other code if there is a other present.
