Hydraulic flow
Cat1277
I have a new holland l180. Ritchie br specs says it has a34 gallon flow . Is that’s high flow? I just bought crusherbucket that requires 29 gallons of flow. If I need to can I add a high flow kit to my machine? My dealer says they do not know of such a kit ?.. dale
Assuming it is similar to my LS190B. You have a switch for high flow or normal flow up by the instrument panel that is labeled high flow. You also have a 2nd set of hydraulic attachment fittings that are different in size for a total of 4. I was told that it is very expensive and labor intensive to install a high flow system if you can even get the parts for an older model but it can be done. This is why I bought one that had it factory inatalled. I also have high flow emblem on the machine. If you don't have the high flow, normal flow is 19 gpm I believe.
