bobbycat630
- Joined
- Apr 19, 2021
- Messages
- 4
Greetings everyone… I am brand new to the forum. I’ve owned a several steers, of those a few Bobcats all older models. I’m by far no heavy equipment mechanic, but I can usually figure things out if I go slow. With that said this question is going to sound pretty rookieish. My current machine is an older Bobcat 630 (not the S630). It has the Wisconsin VH4D. I’m changing out hydraulic fluids and have it drained completely. I’m wondering if the only fluid fill location is the one behind the seat and debris cage opposite from the fuel fill side? Will that upper fill location feed all the way down to the lower reservoir underneath? I’ve filled it full with at least 2 gallons to the point of overflowing out of the fill spout. I had the engine and drives running as I added fluid, but so far no fluid seems to be flowing to the pumps or through the system. I know the total capacity is about 9.5 gal. I decided to just shut down the operation until I get some feed back from a pro. Thanks in advance for any help, Bobbycat630
