hydraulic accessory third return line goes where?? 753
desross
Hi folks i want to set up a third return ( pressure relief line on the front of the bobcat 753c ) so i can run a hydraulic motor at the front. at the moment i only have the 2 flat face couplings. MY question is where do i plum this third coupler line back too. ( Is there a port on valve bank )? If someone out there has a photo of where it goes that would be great. cheers des
On my A300 it shows the line going to “the case drain”. It appears to connect by a three way hydraulic fitting to the hose that comes out of the hydraulic resiviour tank. There is also a brass filter in the line.
