Bobcat Skidsteer Forums
Hydralic light staying on ?? Already replaced pressure switch
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 20433" data-attributes="member: 82"><p>The sender on the bottom is there to detect if the main hydraulic filter is plugged. The only other thing it it could be is a wire may be worn through and it may be grounding out causing the light to come on.</p></blockquote><p></p>
[QUOTE="Tazza, post: 20433, member: 82"] The sender on the bottom is there to detect if the main hydraulic filter is plugged. The only other thing it it could be is a wire may be worn through and it may be grounding out causing the light to come on. [/QUOTE]
Verification
Post reply
