Other Brand Skidsteer Forums
GEHL Skidsteer Forum
Hydra Mac Mitey Mac 8B
Reply to thread
Message
<blockquote data-quote="joer" data-source="post: 59626" data-attributes="member: 7999"><p>didn't realize this was an old post, but incase any one is reading, about the lunging forward or in any direction for that matter, there is a couple of remedies, Either reach under the seat and bend the Control rods in the direction that takes the pressure off the hydra stat drive gears or take out the seat and twist the ends of the rods. If you don't want to do that I believe there is a set pin on the shaft of the drive gears.</p></blockquote><p></p>
[QUOTE="joer, post: 59626, member: 7999"] didn't realize this was an old post, but incase any one is reading, about the lunging forward or in any direction for that matter, there is a couple of remedies, Either reach under the seat and bend the Control rods in the direction that takes the pressure off the hydra stat drive gears or take out the seat and twist the ends of the rods. If you don't want to do that I believe there is a set pin on the shaft of the drive gears. [/QUOTE]
Verification
Post reply
