hydra mac 8a
lgehring
Good evening I am new to the forum. I need help with a hydra mac 8a sn2759. It has a triple sheave belt drive off the Onan crank shaft to drive the right and left hyd pumps that drive the transmissions. It was cobbled when i got it. The belt pulley was coupled to a thin walled tube by a double roller chain with a 1/4 in bolt in the pulley end and one in the right hand pump shaft. I used a heavier wall pipe. The end of the pump shaft was broke out from the bolt hole out to the end of the shaft. I drilled a new hole. Everything working for about 20 hrs or so before the pipe and bolts failed. I have priced a new pump shaft at about 250.00. I am not sure what is really supposed to be between the belt pulley end the right hand pump. I would like to find used parts. I need help. Thanks ,Lowell
