hyd. drive belt
redbarn
anyone have any info on a three satr B-47 belt, this is for a bobcat 440B with akohler 18 magnum engine.... thanks or a cross reference for a belt... it looks like a pretty hefty belt....
B-47 is a standard size, have you tried an auto store? it should be easily available, you may even have the option of raw edge or a power rated belt. I use this sort on my ride on mower for the cutting deck.
Are you sure about the 47" belt? My 440B used a 49" belt back when it had a Kohler in it. I bought my last belt at TSC, works fine. HTH - SR
“B” section V belts are 3“ longer than the number. A B47 belt has a 50” outside circle. A 5L500 belt would also work its 50“ and the same top width.
Thanks for all the help. i went to carquest and got a B-47 belt 50" long. i save a lot of money....
