I see no real answer was put up other than references.
The TL10 has one large bolt on each side of the cab opening. Sitting in the operator seat the head of the bolts are visible in the front corners of the lower frame of the cab on the left and right. Remove one at a time and hold the cab down when removing the last bolt if the lift cylinders are in good condition. The lift cylinders will make lifting the cab very easy as it may try to rise on it's own once the last bolt is removed. The cab lift lock pin will need to be removed, if it is in place, before un bolting the cab. Facing the engine at the rear of the machine the lock pin should be at the upper left of the rear of the cab. Place pin in holes after raising the cab to lock it in place. Be Safe.
