Bobcat Skidsteer Forums
How to move a borken down bobcat
Reply to thread
Message
<blockquote data-quote="Fishfiles" data-source="post: 48987" data-attributes="member: 782"><p>what other equipment do you have to work with , an excavator , at least 16,000 lb class that has a dozer blade works well to move it , you walk up behind it and put the blade under the rear of the machine and lift up , you put the boom over the cab into the bucket and catch the lip on top the bucket and you don't have to get it all the way off the ground , just the weight off it and you can walk it where ever you what , another way is with a fork lift , come in from the rear and put the mast against the back door with it tilted all the way forward , put a chain around the mast and hook to the machine , tilt back and it will get it off the ground if lift is heavy enough or the weight off it enough to move it if not ----------------there are alot of other ways we have moved them around , what do you have to work with</p></blockquote><p></p>
[QUOTE="Fishfiles, post: 48987, member: 782"] what other equipment do you have to work with , an excavator , at least 16,000 lb class that has a dozer blade works well to move it , you walk up behind it and put the blade under the rear of the machine and lift up , you put the boom over the cab into the bucket and catch the lip on top the bucket and you don't have to get it all the way off the ground , just the weight off it and you can walk it where ever you what , another way is with a fork lift , come in from the rear and put the mast against the back door with it tilted all the way forward , put a chain around the mast and hook to the machine , tilt back and it will get it off the ground if lift is heavy enough or the weight off it enough to move it if not ----------------there are alot of other ways we have moved them around , what do you have to work with [/QUOTE]
Verification
Post reply
