Bobcat Skidsteer Forums
How to keep a skidsteer from getting stolen?
Reply to thread
Message
<blockquote data-quote="Fishfiles" data-source="post: 25103" data-attributes="member: 782"><p>A hidden fuel shut off valve on the fuel pickup hose that could even be electrical , a hidden electrical disconnect switch and such will slow them down , if they know what they are doing and really want it they will get it , Lojack it and hope the best , the ignition switch can be rekeyed as the rental houses around here do it them selves , the mechanic showed me the kit the locksmith put together for them and they change the pins to another accept another key , I seen a few machines with a Club device that locks thru the cage and graps the steering levers , a steel plate over the front access with locks under steel boxes where they can't hit or cut the lock</p></blockquote><p></p>
[QUOTE="Fishfiles, post: 25103, member: 782"] A hidden fuel shut off valve on the fuel pickup hose that could even be electrical , a hidden electrical disconnect switch and such will slow them down , if they know what they are doing and really want it they will get it , Lojack it and hope the best , the ignition switch can be rekeyed as the rental houses around here do it them selves , the mechanic showed me the kit the locksmith put together for them and they change the pins to another accept another key , I seen a few machines with a Club device that locks thru the cage and graps the steering levers , a steel plate over the front access with locks under steel boxes where they can't hit or cut the lock [/QUOTE]
Verification
Post reply
