Other Brand Skidsteer Forums
New Holland Skidsteer Forum
how do i remove the mounting plate on my LS160?
Reply to thread
Message
<blockquote data-quote="Earthwerks Unlimited" data-source="post: 27844" data-attributes="member: 1300"><p>Depending on where you bent it, when I bent mine, all I did was "dump" the mounting plate about halfway. On the side that is bent back too far place a 4x4 between the stiop on the loader arm the stop on the plate. Power back the plate about twice as far as it's bent, dump it and get out and align it. Keep doing this until it's straight. If you bend it too far simply put the 4x4 on the other side and repeat.</p></blockquote><p></p>
[QUOTE="Earthwerks Unlimited, post: 27844, member: 1300"] Depending on where you bent it, when I bent mine, all I did was “dump” the mounting plate about halfway. On the side that is bent back too far place a 4x4 between the stiop on the loader arm the stop on the plate. Power back the plate about twice as far as it's bent, dump it and get out and align it. Keep doing this until it's straight. If you bend it too far simply put the 4x4 on the other side and repeat. [/QUOTE]
Verification
Post reply
