Hi- Flow System
kensteer
So here is a question I think I already know the answer to. First, what is the flow rate on on 743? I guess this also depends on how strong the hydraulic pump is. Is it possible to covert this old machine to a high flow system? I am assuming not. In order to run attachments such as one of the new disc mulchers; that grind up trees and brush, it takes a lot more flow than a 743 can produce.
The flow rate on a 743 is 11 GPM. On late model 743B it is 12.1 GPM. Both pump capacities are rated @ 2850 RPM.
As for converting the machine to a high flow…. It would probably be cheaper to just buy a high flow machine.
