help with error message
yardpro
I have a 2004 t200 and am having a big problem. I just changes the seal and o-ring on the swash plate shaft (and the triangular piece that the linkage arms hook to, that steer the left drive motor). we pressure washed the pumps and linkage area... now after we got everything put back together the machine worked fine for a few minutes, then i got out to hook up an attachment, then the problem started.... The screen is saying "input", then when i switch the key on it says "none" Whenever i turn the key on the front lights come on and i cannot turn them off. the machine starts and runs fine, but i cannot move it or position the arms, bucket, etc... when i press the "press to operate" button nothing happens.... I did get one error code of 03-09, but that's it... when i hold the light button to try and get a code, nothing happens.... any ideas? i called the bobcat dealer and they are stumped..
Probably got some water into an electrical connector...start with unplugging connections and check/dry out with shop air.
as of yesterday it would start and i could drive the unit and work the arms but the panel still says input-none...
It does sound like water in a connector or in the left dash panel. Input means the panel is not getting the correct signal from the controller.
