Bobcat Skidsteer Forums
Help! S185 won't stay running.
Reply to thread
Message
<blockquote data-quote="thetool" data-source="post: 25771" data-attributes="member: 1534"><p>Hmmmm........Interesting.</p><p>Code 14-02 is "fuel shutoff pull solenoid error-on" which means that the controller sensed voltage to the pull coil of the solenoid when it should not have.</p><p>This has nothing to do with a shut-down, or a warning light on the dash. I do not know, however, if this fault causes the fuel shutoff solenoid to trip and require a reset, causing a non-monitoring system shutdown. LOL this is my own terminology, does it make sense?</p><p>Anyway, as you may already know, many codes clear when you turn the machine off. Also, codes will scroll in the window, you can have more than one.</p><p>It sounds like you experienced a system shutdown, and you are correct that it was probably due to heat, since you were able to come back and finish the job. The 14-02 does not make sense here, tho......</p><p>Your dealer, or someone with the correct equipment, can provide you with a printout of warnings and shutdowns, a history of the last 40 occurrences. I would get a copy ot this for study and peace of mind.</p></blockquote><p></p>
[QUOTE="thetool, post: 25771, member: 1534"] Hmmmm........Interesting. Code 14-02 is “fuel shutoff pull solenoid error-on” which means that the controller sensed voltage to the pull coil of the solenoid when it should not have. This has nothing to do with a shut-down, or a warning light on the dash. I do not know, however, if this fault causes the fuel shutoff solenoid to trip and require a reset, causing a non-monitoring system shutdown. LOL this is my own terminology, does it make sense? Anyway, as you may already know, many codes clear when you turn the machine off. Also, codes will scroll in the window, you can have more than one. It sounds like you experienced a system shutdown, and you are correct that it was probably due to heat, since you were able to come back and finish the job. The 14-02 does not make sense here, tho...... Your dealer, or someone with the correct equipment, can provide you with a printout of warnings and shutdowns, a history of the last 40 occurrences. I would get a copy ot this for study and peace of mind. [/QUOTE]
Verification
Post reply
