No lights, no clicks nothing whatsoever.A skidsteer will run for hours on only the battery. Is it completly dead, do you headlights? Starter just click, need more info.
Your might have a bad fuse, hot or ground cable, Take your test light and see how far the power is gettingNo lights, no clicks nothing whatsoever.
will check fuses 2marrow thanks. myronYour might have a bad fuse, hot or ground cable, Take your test light and see how far the power is getting
