Bobcat Skidsteer Forums
HELP - Bobcat 722 almost stalls engine when trying to turn
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 95976" data-attributes="member: 82"><p>What happens if you push up against a non movable object? Does the pump squeal badly or does the engine just bog down?</p><p>It could be low compression or the govenor is not set right. When the load increases the govenor should give more fuel, if it's not right it will just bog down and stall.</p></blockquote><p></p>
[QUOTE="Tazza, post: 95976, member: 82"] What happens if you push up against a non movable object? Does the pump squeal badly or does the engine just bog down? It could be low compression or the govenor is not set right. When the load increases the govenor should give more fuel, if it's not right it will just bog down and stall. [/QUOTE]
Verification
Post reply
