Bobcat Skidsteer Forums
HELP!!!! Bobcat 553 interlock problem - HELP!!!!!!
Reply to thread
Message
<blockquote data-quote="rodbuilder" data-source="post: 98985" data-attributes="member: 11975"><p>Fishfile ................ You responded to a post of mine back in 2011 regarding the Bobcat 553 magnetic seat switch and told me then, " if you hae a seat BICS you can lift the seat , take the sensor off the bottom of the seat , put it in the operate positon and tape and strap it up so it tells the controller someone is always in the seat". We found a corroded terminal on that machine, but I'm having the same problem with another 553. PLEASE tell me what you meant by this because it means nothing to me as you wrote it. How do we put it in the operate position??? HELP!!!</p></blockquote><p></p>
[QUOTE="rodbuilder, post: 98985, member: 11975"] Fishfile ................ You responded to a post of mine back in 2011 regarding the Bobcat 553 magnetic seat switch and told me then, " if you hae a seat BICS you can lift the seat , take the sensor off the bottom of the seat , put it in the operate positon and tape and strap it up so it tells the controller someone is always in the seat". We found a corroded terminal on that machine, but I'm having the same problem with another 553. PLEASE tell me what you meant by this because it means nothing to me as you wrote it. How do we put it in the operate position??? HELP!!! [/QUOTE]
Verification
Post reply
