General Skidsteer & Technical Topics
Shop Talk
Help-A-Newby... auxiliary hydraulics skidsteer hack
Reply to thread
Message
<blockquote data-quote="vinito" data-source="post: 96649" data-attributes="member: 12954"><p>Sorry, I left out some important info.</p><p>If you click on that link above, you have to choose which spools to include. For the spools I chose D section with float for one (for lift) and B section with spring to center for the other two (for tilt and aux.). Pretty standard for skidsteers, but there are several to choose from with other add-on options if you so desire. Also, since it's a stack, if you want to add another spool for some reason in the future or change the end blocks or whatever, you just buy what you need and a longer bolt kit if there are more sections, and you just slip it in and it will go right back together.</p></blockquote><p></p>
[QUOTE="vinito, post: 96649, member: 12954"] Sorry, I left out some important info. If you click on that link above, you have to choose which spools to include. For the spools I chose D section with float for one (for lift) and B section with spring to center for the other two (for tilt and aux.). Pretty standard for skidsteers, but there are several to choose from with other add-on options if you so desire. Also, since it's a stack, if you want to add another spool for some reason in the future or change the end blocks or whatever, you just buy what you need and a longer bolt kit if there are more sections, and you just slip it in and it will go right back together. [/QUOTE]
Verification
Post reply
Shop Talk
