I have a 1987 743. ran fine last summer. I've tried several times this winter to start it with zero luck. It has been very cold in Michigan - sometimes down to -15 degrees F. Today it is 47 degrees. I glowed for 30-60 seconds, cranked. It won't fire. I get some some puffs of smoke while cranking. Sometimes a sputter. I've checked the 3 easy glow plugs to check - they are good. The glow plug relay is good. Starter is good. I took one fuel line off where it goes in the cylinder head. The fuel was liquid. I had my wife crank the starter - about one per second a small drop of fuel came out of the line. is that right or does it shoot? I ermoved the line closest to the back of the machine that loops from the left, them up and down and to the right. What else can I check? Could it not be getting fuel? Could I have messed something up trying to start it many times during the cold and having it never fire up? Could I have caused damage? What would be causing it to not fire? I've heard of diesel fuel gelling up. How could I tell if that is the problem? How do you "ungell" it? What else can I try? Any and all help is appreciated!
