Hello, I'm in need of a right rear axel for a 1999 Daewoo DSL 601 skidsteer. Any help would be appreciated.
ricck r
Hello everyone, I'm in desperate need of a right rear axel for a 1999 Daewoo DSL 601 Skidsteer. Can't even get one from Korea, any help would be appreciated. Thank you
Can you measure it? Or just measure the bore and shaft size, and then measure the thinness of the original? Some pictures of the seal would help.
Are you looking for the axel shaft?
I have the parts manual for that machine as I used to have one.
The number on the shaft is D460089, 2 required since right and left are the same.
Of course there about 20 part numbers for the whole thing since it is not sold as a complete assembly.
I have no idea if it is available anywhere.
    141.4 KB
    189.1 KB
Goodness me. I thought you said axle SEAL, not shaft!
Load like the SEAL is available from your local Bobcat dealer as it is a Doosan number.
The axle though... What went wrong?
Whatever this means!!?
[H1]D460089 SHAFT ASSY, SKID LOADER[/H1]
Doosan OEM quality parts are subtle and more basic is course harder to coordinate that these Original Equipment Manufacturer Doosan parts were passed on to your staggering equipment site.
Overpowering equipment Doosan OEM parts we delivered to fit Doosan significant mechanical assembly and will serve you any more drawn out than a standard not ensured parts. Each veritable part is made for a particular inspiration driving a mind-boggling mechanical assembly bolster.
We do have broad assortment of Doosan OEM overpowering equipment part close-by and we have an opportunity to get you significant mechanical assembly part you require as speedy as would be prudent. We do engineer transport and will talk with every one of you the way in which that demand will be passed on.
Do whatever it takes not to defer to think of us as or make an email in case you require any Doosan part that is recorded in our site. Either cancel us on the possibility that you require a specific Doosan overpowering equipment OEM parts we will find and transport it as fast as time grants.
    35 KB
[h1]D460089 SHAFT ASSY, SKID LOADER[/h1]
I still can't find any significant mechanical assembly parts anywhere
