hard to get to
1gr8bldr
Any advice on getting to the hydraulic hose just behind the main lift cylinder. The connection down near the bottom. I pulled the battery but still could not get a wrench on it. Is their a trick?
You still need to get enough leverage to crack them though. Getting the spanners on is just the first part of the battle i'm afraid.
Yes, they were tough. I had to get hold of both nuts otherwise it would twist the hydraulic pipe. Could not hold both by myself but a big pipe over the end of the wrench sticking out, wedged, worked.
Glad you sorted it out. A helper sure can be an asset doing this, but then they can be in the way too :)
Every good skidsteer mechanic should have crow foot wrenches and some wrenches you can cut up or heat and bend
I recently had a similar problem on my machine, with the lines that run up inside the frame to the boom and out to the bucket cylinder. The hoses were shot, and the connections to the hard lines were up inside the frame. No room for even a crows foot wrench. The only way I could see to get them out would be to pull the engine/hydraulic pump assy, so that the entire hard line could be shifted to get to the connection. No way I was doing that. So I cut the hard lines in a spot that could be easily spliced with a hydraulic compression fitting union. Worked out great. And when I have to change the hoses again in 25 years, it will be a much easier job!!
