Hand and foot controls not working
Tiptopw30
Recently purchased a 2005 s150 bobcat with 1100 hours and on first day of use my hand and foot controls stopped working and the acs light had come on, was wondering if anyone has had this issue any hints or cures would be appreciated!!
It will set a code. While it is having its fit, hold the headlight button. Once you have the code, we can go from there. Probably a bad actuator.
Thanks for replying sorry didn't list code 32-65, funny though was just out there and foot controls were working but no joystick.
32-65 is ACS sensor supply voltage out of range
Do the normal wiring check
Battery voltage, bad ground, corroded connectors and rubbed wires.
Tried that all connections and wires look good, fuses also good.
I took a look at the flow chart for the code and to be honest, take it to a dealer. There is a very good chance it is a bad acs controller. Unless you have a spare, it had to verify that is the fix before replacing it. Also, it needs to be programed with service software when replaced.
