grabber closes on it on when u crank it up
codycarroll
I have a 2006 t300 bobcat when you crank it up the grabber on it , it automatically closes itself, keeping it from opening. can you help me out with this problem
Sounds like your aux hydro is on or stuck on fiddle with the switch and look at the solinoid for a bad rubed wire loose or bad connection craped up or just bad
Are you referring to a hydraulic grapple? If so, the trigger on the right handle may have a bad spring. If the spring is bad the trigger will only rest in the downward position, you will have to manually hold the trigger up for the grapple to open. If this is your trouble, take some electric tape and tape the trigger in the up position, than the side to side, thumb control will open and close the grapple.
